Deco x50 3000 extender
Quick question if I use two of these in different rooms and keep the zayzi router as the main router will the decos act as stand alone repeaters. As I’m sure you can set up a mesh network like this just needing confirmation
They would act as mesh nodes with a different SSID as default, one will be primary, the other(s) will be slaves. Just set them as mesh rather than router when going through the Deco set-up.
That’s fine thanks for that just need them so I don’t have to run wires between rooms and would only need 2-3 ports anyway also just to confirm they wouldn’t need to be wired to the main router at all
