@Hopper is right that placement really matters. For best speed capability (on paper) with Ubiquiti you will want the U6 Enterprise APs which have WiFi 6E - of course your devices need to support it too.
It also has a 2.5gbps ethernet port so it can in theory support the full 2500/2500 Cityfibre package, although you’re unlikely to ever get that from a single client. If you are trying to get the best throughput then always pick an option where your APs are wired in (and avoid daisy chaining unless your APs have significantly faster ports than your internet connection).
I have now upgraded all my Unifi APs to the wi-fi 6 versions and currently have - in this purchase order - a U6 LR, U6 Pro and U6+. Certainly overkill for 2.4Ghz but to get a consistent 5Ghz signal in a house with internal brick walls, it seems better to saturate with multiple APs at a lower power, than less on a higher power. I have also been very wife-friendly with my positioning of these with 2 up in the loft resting on the ceiling boards, and one tucked away in the integrated garage.
They do take a fair bit of tinkering to get everything running well - power levels, positioning, frequencies to use etc. But, from the locations that I generally use in the house, I get around 600-650Mb down on wi-fi 6 supported devices which is probably not that far off from what’s realistically possible,
Depends on how much time, effort and headaches you want to deal with. I have found that it’s very easy to totally screw it all up by making one seemingly innocuous change with the Unifi stuff. Conversely, you should get much better performance when set up correctly and is a lot cheaper than Cisco or Ruckus kit.
One final note. Unifi have just announced their U7 Pro AP so that might well be worth looking in to for futureproofing.
I don’t have any devices to take advantage to be honest. If I were in the market for an additional AP mind, I would probably go with the U7 Pro as it’s not much more than the U6 Pro. I may well dump the LR and pick up a 7 Pro, just to see if it improves things for standard Wi-fi 6 devices, but I think it’s a bit more power hungry and hot, so not so sure.
Ah, the flaming money pit that is Unifi. I wouldn’t get too excited about the Wifi7 side, its still way too early and client support and practicalities of mobile devices make it less beneficial, also if your AP needs a fan, thats just not cool, literally! The rest of the U7 range should be dropping in the next few months from what was said at the conference, a U7 Lite is probably a better bet for most imo and I say that as a U6 Pro owner. I am more interested in the new router hardware thats seemingly coming….
We’re talking about home user kit here, not enterprise, hence why Unifi is even in the discussion (though they did state they want to move into enterprise last week at the conference), and in that market its an expensive ecosystem for what it does. Also nobody with any credibility has ever suggested wifi should be used to move big data quickly, that won’t change wifi 7 or anything you are running today, tomorrow, next year or for the rest of the decade. You can’t defy the laws of physics, light travels faster than radio and cable is still king with a clear path to 400Gb and beyond - if it wasn’t then nobody would bother laying fibre.
C’mon, admit it, you’ve had one too many Quiet wifi and repeating that fibre is used to AP’s
We were discussing consumer grade hardware, you claim there are much more expensive options than a UDMP-SE and AP but keep neglecting to tell us what? I considered the QNAP QHora and Synology options, The TP Link 8411 + Omada (essentially a UDMP), even the RGB encrusted ASUS garbage, but i’m coming up short, so as you can think of far worse, feel free to enlighten me.
The CCTV/streaming examples also don’t add up, no sane person who is implementing a secure system uses wifi, it doesn’t matter if they are the customers or home users you mention. No reputable installer will spec any form of wireless camera unless it’s for something like a doorbell. CCTV is not high bandwidth, even with main and sub streams running because H264 and H265 hardware encoding on camera is a thing, and you’re not generally recording 4K/30 or similar, it’s all low bandwidth and reduced frame rate depending on the area and the risk. As for streaming, commercial 4K steaming tops out at 40Mbit and a full 4K BD REMUX tops out at 128Mbit depending on the title and scene. Large scale commercial AP installs aren’t about big data, they’re about high density/user count with a limited amount of bandwidth, thats why Unifi often over state the maximum user count on AP’s vs Omada and Aruba for example, but again that has nothing to do with the consumer stuff being discussed.
Wifi is a convenience for mobile devices and IOT, NBASE-T access points with big radio numbers are still port limited, and in the consumer space, thats 2.5Gb still on the higher end options.
