Right have it setup.
Was a real pain migrating over my network and static IP devices. The Route 10 is a work in progress, the DHCP server and GUI need some work, were I had most issues with converting DHCP assigned IP to STATIC. The firewall is basic but functional. So I look at this at a new Startup product so will be rough around the edges.
My take on it is HOMELAB(Wireguard/Openvpn,) I would say YES, with caveats at present no PBR VPN, country blocking, IPD/IDS, howver if you tinker
intresting product
For home users with a flat LAN - maybe fine, for Advance users or those runing servers , need remote acesss— NO too bleeding edge.
Considering it’s only been out a month, will be a several more firmware releases to get key features implement. I setup the route 10 using the cloudcontroiller - will be moving to a self hosted contoller on , Raspberry Pi. Was a time consuning and fustrating migration…now its running, works well with some niggles,I am willing to live with these
On the Yayzi 900/900 service was using a UCG-ULtra as the router, nothing fancy, a VPN CLINET running, some firewall rules, local DNS piholes and 5 Vlans.
My main issue was the poor inter-vlan speeds. Crossing VLANS say Phone to Camera or IoT VLANS there was a LAG. The route 10 is blistering fast, I am getting almost the same response as being on the VLAN its self. Qualitative … need to do some proper testing. but based on speed things load, noticfiations arrive at the time of an event not 10 seconds after.
Have its setup with WAN Port 1, Port 2 and 3 Poe to 2x U6 Access Points SFP 1 to USW-24-PoE switch.
After almost giving up last night with the migration, I am this moringn looking at it as a triumph. The basic rulles Firewall pass GRC shields up - albeit had I had to change ICMP Ping IPv4 from Accept to Drop. Going to move over some firewall rules over teh week and see. DNS is being served by the Pihole the perfectly on all networks. Firewall UI is basic so manual but I am willing to give it a go.
Another observation - its cool runnings - 40C-45C thats with one SFP DAC and 2 PoE+ running. Be intresting to see as more features are added how it performs.
Speedtest WIRED: directly on the Router.
Here it is :
