Archer AX53 - can't connect
I wonder if anyone can help? I today bought an Archer AX53 router. I thought it would be a simple case of plugging in the WAN cable and installing via the Tether app and I’d be away. However, no matter what I try I can’t get the internet to connect, the light stays amber. The Yayzi supplied router is connecting ok, but this one won’t. Has anyone got any advice?
Thanks in advance.
You need to set vlan to 911 and DHCP :slight_smile:
You’re a flipping legend! Thanks mate…2 hrs banging me head on the wall at an end - cheers :blush:
It’s those pesky VLANs!
No problem! Glad you got it sorted!
