Hello everyone. I have an Asus XD5 mesh system and have been attempting to connect it to the router, but it doesn’t read it as a Mesh System and it tries to take over the job of the router whenever I connect it.
I don’t think the XD5 has VLAN settings on it… so you’ll definitely need the Yayzi router in first
If you set the XD5 into Access Point mode, it should generate the wifi mesh, but still use the Yayzi router to do the whole routing side
Totally agree… I saw Asus only mention a couple of bits of kit that do VLAN… but then a forum page talks about it on the XD5 (although I didn’t read it… could be LAN side…)
This link talks about setting up VLAN in generic terms: https://www.asus.com/uk/support/faq/1034366/
If you have that option, you could remove your Yayzi router (depending on your internet speed/port speed on the XD5)
The problem is, I’m not sure how to set it up as an Access Point straight away, the only option on the app is to set it up as a router, with it’s own WiFi network and password.
