Anyone know when the “change plan option” on the account will be fixed?
It did work before but for the last few weeks it has stopped offering the different plan options.
When the address checker is fixed
You should be able to reach out to [email protected] with the plan you would like ![]()
I was told that it cannot be done until the address checker is completed and working after trying to get the upgrade!
