First off, what kind of storage are you on?, Are you on the NVME or? SATA 3 SSDs?
I find the download speeds on Steam a little bit inconsistent as well however it depends on how the game is compressed or if it’s even compressed at all
I recently downloaded red dead redemption two on the rockstar launcher and it downloaded at a full 245 MB per second all the way through the download however if I download GTA4 on Steam for example it will maybe cap out at 1.2 GB/s
I would suggest opening up task manager and looking to see if CPU is maxed out. Like @L0rdVerga says when it’s compressing then you won’t get no where near your max speeds unless you have a top end pc.
After the latest update installed, explorer.exe was crashing and opening over and over and over and over with no end in sight… I used system restore and all was ok again… I told WU to not install that update…
It did it anyway and back to explorer crashing over and over.
System restore failed me the 2nd time with no restore point listed!
Uninstalled the update… explorer still borked. Sod it wheres my USB stick! xD
Moved to Zen and right away, the speeds on steam have stabilized. So something on the Yayzi side has been causing an issue. Will find out if Discord streams are better later today.
