Hi when best to contact you please
We were unfortunately unable to get his X 50 deco to detect an Internet connection even after setting the VLAN in advanced settings. He is happy to use the deco as access points though, We just need to turn off his Yayzi router Wi-Fi
It was firmware version 1.5 I believe I saw
Thanks for your help today it’s very much appreciated and I’m sure you can see what I’m up against . I have returned system back to added on to original router and all working and I also managed to check updates for the deco and all up to date
It’s actually a lot more effort than you might think to reset or even reboot it. They don’t put the obvious settings in the most obvious of places.
The main problem was, It wasn’t obtaining a WAN IP, Even with VLAN 911
Things we tried:
Restarting the ONT
Resetting the Deco
MAC address clone from the Yayzi router.
I will add that when he contacted Yayzi for Support, They just told him to “ Go to the forum” Which while a valid answer, Is not really an answer I would have given. I don’t believe they even try to help.
Granted, since it is own equipment, they don’t have to, However, they could’ve tried.
Given that you have also stated that the latest OS version is 3.0 and he is stuck on 1.5.5, I think he is likely right when he said it may be a duff unit, While on the phone
It does seem like he may have v1 Hard revision As the firmware update seems to match
The only thing we could have probably tried, Is turning off the auto WAN port, But it did seem to recognise when the ethernet cable was plugged in so maybe that wouldn’t of worked
It’s a lot of hassle to keep trying this, so it’s probably best just to leave it as it is as long as he’s happy
