Default security settings for supplied router and issues with pairing tapo plugs
Hi all I’ve changed this a few times and can’t rember the default if it was wpa wpa 2 or wpa 3 if someone could let me know also I’m having issues connecting my tapo WiFi plugs as they always say offline could anyone help ?
The default encryption type will be WPA2 as that is the most compatible with devices
Which one though
Do WPA2/3
WPA isn’t used much anymore
Thanks just as a heads up to anyone else having connection issues you need to set your 2.4ghz channel to a specific channel not auto or it won’t connect :+1:
Mine work just fine on auto
