My direct debit date has always been the 10th of every month, when you changed or updated your system it changed to the 1st.
I’ve spoken to Liam, I’ve asked on WhatsApp and emailed multiple times for it to change back to the 10th without response.
I would like it changed back to what it was as the 10th of every month
dann
2
Hello,
Have you opened a ticket with Yayzi, or contacted them via WhatsApp?
+44 7356 076644 Is the WhatsApp number
I’ve emailed at least 5 times, messaged on WhatsApp the same amount but the WhatsApp number is no longer in use.
No response whatsoever
Also never had any response to any ticket I’ve submitted
dann
5
Have you tried vis Facebook messenger?
Someone is on this for you
Can you let me know if this has been sorted?
