Disable 5GHz to go with 2.4
Does anyone know a simple way to just go with 2.4GHz? I can’t see anything in the router settings, just need to set up a speaker which only goes with 2.4GHz & I think it’s not connecting cause of the 5GHz
Once connected runs on it’s own 5GHz Mesh system(Formation B&W Bar)
Silly I know in this day and age.
There’s a little “enable” tick box if you go to the wireless settings. Just untick that and apply.
You might have to disable “band steering” first
Many thanks for that, got it going :+1:
