Disney plus and bbc iplayer not working on yazi home broadband
Apps work fine when tethered to my 5g connection but wont play any content through bbc iplayer on yazi home broadband connection and disney plus app will not launch. This the same across mutiple different devices windsows mac and android.
We’ll take a look for you :slightly_smiling_face:
@Yayzi_Team - I’ve got a similar issue as above when it comes to the apps, but also with my WiFi calling.
From researching online it appears EE only allow WiFi calling when in the UK. My IP address appears to be based in US and hence I’m having this issue. Can you resolve this please as I’m really struggling to get alot of my work done. Would appreciate the help. Thank you.
The network team are on this now guys. We’ll get you sorted
Thank you. I truly hope it does get sorted. Appreciate all the help.
Any updates on this as apps are still not working
@Yayzi_Team we are having the same issues with our broadband to a point where its kicking us out of games, and work from home software. this needs sorting ASAP
What ip range are you on? Mine has been solid all day. I have been gaming non stop whilst the wife is working from laptop. Not a single issue
unsure but ill have a look, ATM moment it thinks I’m in Atlanta
this is what we get when we try and sign in on national lottery
yeah just done the same thing just says atlanta instead of boston
it seems to change very couple of days its irritating
yeah thats what i mean
Hmm. The locations shouldn’t keep changing. This is really odd. We’re investigating immediately, we’ve got a company dealing with geolocation databases now. So this should speed things up significantly for everyone.
We’ll get it sorted!
Its still an issue
Which IP range are you on? Disney+ is not an issue on 79.135.x.x
My SkyGo doesn’t work either. Just keeps showing a blank black screen when I select the channel.
We’re speaking to Sky about this - should have an update shortly.
Chased the company for an update :slight_smile:
It says cogent because thats who they would have brought/rent the block from. It looks like some sites have the IP block geolocation cached locally. If you try other sites it will show the updated Geolocation here is a site that checks 4 different IP Databases dnschecker.org
Might want to edit that hyperlink and remove your IP from it, unless you aren’t bothered. :slight_smile:
