Exciting Network Upgrade – Big Improvements Ahead!
Hi everyone,
We’re excited to share that we’re in the final stages of an incredible network upgrade that will bring huge benefits for you! As we work closely with CityFibre to transition our connections to the new network, we’re making sure everything is perfectly set up for an even better experience.
To ensure a smooth transition, we’ll be applying some temporary traffic shaping during peak hours (between 5pm and 10pm). This will help maintain strong connections and keep latency low as we complete the upgrade. Rest assured, this is a short-term measure, and we’ll keep you updated with our progress every step of the way.
Once finished, this upgrade will deliver lower latency, improved peering, and a smoother overall experience. It’s a big step forward for Yayzi, and it will futureproof our network to support the rapid growth we’re experiencing—so you can expect even better service going forward!
We truly appreciate your continued patience and support as we work to bring you the best network experience possible.
Thank you for being part of this exciting journey!
Kind regards,
Yayzi Network Operations Team
