Extremely slow / Can't connect to router from WIFI devices
Anyone else having issues today? My connection is extremely slow. Loading websites is painful, >30secs. Speed test (over WIFI) was ~900mb although its now down to ~300mb (VPN disabled). I’m on a 2gb connection
PC/laptop/mobile all connected via WIFI but wont connect to 192.168.0..1 (obvs fine from wired PC)
Echo device won’t connect to the internet
Google docs keeps telling me I’m offline every 2-3 mins as well
Have you restarted your WiFi router? What router are you using? Does the SSID show when you search in the wireless list?
yep rebooted. I’ve got the EX820v
Not sure what happened but it seems to have cleared.
Part of the issue was all my devices were switched onto the guest network. Might just be my guest network that’s really slow
still only getting 1gb (on wired) but at least its quick again
