Hi guys, I’ve only recently switched to Yayzi on Tuesday, and ever since I’ve been having issues with high lag spikes intermittently throughout the day. Most often happens in the evening around 6pm-12am, but I’ve realised today on a Saturday the ping spikes incredibly high throughout the day.
I’ve been impressed with the download/upload speeds, but honestly as gaming is my main use of the internet it’s quite unusable. Ping spikes up to 1800 in Valorant, lasting for a few minutes at a time, is incredibly frustrating.
Anyone having similar issues in that area? Or any advice for settings that I need to change on the router? For reference, I’m using a wired connection using a 2.5g switch, 2.5g ports on each PC connected to the network. No downloads going on at the time of the spikes.
Hey thanks for taking the time to respond and help me, much appreciated.
I’m using the router provided by Yayzi on default settings, so I haven’t changed any QoS/Multicast settings etc.
At the time of the issues, only thing going on in the network is two people playing the same online multiplayer games.
I’m very much a novice when it comes to networking/ISP stuff, but I’ve been using some google-fu to understand different things.
MTU - 1500
I’ve ordered a longer network cable to see if going directly through the router rather that router —> switch —> end device, so I’d try that once it gets here.
The only thing I’m not sure how to check/troubleshoot is how to see if my switch is keeping up with the packets coming into it?
Thats embarrassing I’ve put in the wrong link. I’ve ordered that network adapter because I’ve discovered that many users have reported issues with the build in network port on my motherboard (apparently some versions of the Intel Ethernet Controller (2) I225-V on my B550 board are affected) so I’m seeing if a new interface card changes anything.
I use that network adapter myself as an extra interface on a server and it’s capable up to around 2.3Gbps
In regards the switch, yes it’ll be more than capable for gaming. It will match the network adapter you’ve purchased.
Although neither will fix the latency to your router. Its either a line issue or something on the router itself, if you haven’t changed anything from default on the router then you can try
A different router, it’ll need to support vlan tagging on the wan interface
Something like this
I’ve raised a support ticket already, thanks for the heads up with the router. I’d give that a go if there’s no success with Yayzi support, essentially I just need them to confirm that there’s no issues on my line, and that the issues are with my network at home. I’m not fussed, but no point in leaving it out there so I’ve edited it.
