How to upgrade to 2.5gbe cheaply
@nexusmaniac i didn’t know that. Thanks for the update. I’m planning to move to a home next year (2 or max 3 bedroom semi-detached). I’m planning to run Cat6A to all rooms and build a UniFi setup. If I can afford, I’ll get;
  • Dream Machine Pro Max
  • UNVR
  • Network Switch (I couldn’t decide which one to get). It depends on how many cable I’ll need.
  • UNAS Pro
  • U7 Pro AP
  • G4 Doorbell Pro PoE
Any recommendation for the set-up? No idea if I need an aggregation or not.
Also keep an eye on Alta Labs https://www.alta.inc/
some new Wifi 7 later this year
The route 10 shows promise and they PoE switches.
They only have gigabit switches In that lineup currently, There are no 2.5 gig or 10 gig
This is the top of the line
They’ll get there, They’re just not ready yet
