Internet and wifi speeds have dropped
Has anyone speeds dropped for there wifi ?
Hello, would you be able to try a Speedtest over Ethernet?
Over 900mbs but i was going on speeds of 1400mbs not its dropped under 100mbs i have changed wifi channels and rebooted i have this problem several times with yayzi is an i.p address that ny internt service is connected to
How are you testing? Some servers are better than others
Hello,
We’re seeing 2Gbps to your router, no issues on our end as far as I can see. Please ensure QOS is disabled on your router.
Thanks!
Its gone from 1200mbs down to just below 200mbs im sat next the router i should he on a 2.5gb data
Not on WiFi, you won’t get anywhere near that, maybe 1gbps if you’re on WiFi 6, please try via Ethernet, WiFi is very variable
As an example:
My WiFi:
My wired:
Your wireless settings maybe wrong as I never drop below 1gig on wifi 6 and the test server was 750miles away :grinning::rofl:
Its gone up to 1300mbs by wifi its goes it drop when there is work on ther network or works going on, as soon i spoke to yayzi funny enough the wifi speeds increased, you must be in a better static ip for your broadband and my settings on the router is all perfect.
Nothing touched on our end. As far as we’ve been concerned you were getting the speed to the router without issues, so nothing we could have changed :slightly_smiling_face:
It also depends on how fast your network card is in your laptop
