IPv6 Issue - Streaming
Hello all,
Since the update I have started having issues with Disney+ on my Samsung TV. If I disable IPv6 on the router all works. As soon as I enable it I get log in issues (Error 1026).
I’m going to leave it disabled for now.
Has anyone else experiened this?
Dan
Sounds like there are GEO issues with the IPV6 ranges. Basically, a re-run of the all the fun we had with the IPV4 ranges during the infamous migration…
I had the same with Paramount Plus. It said my location was in the US. I’ve also switched off IPv6. Doesn’t make any difference if I have it or not. Yayzi have said they will give out static addresses later on so will wait until then.
I’ve had the same problem. Yayzi support said it’s likely due to outdated geo databases and advised Disney Plus to update them. For now I’ve turned it off.
