Modem mode on pro router hx
is there a way to make the pro router be a modem only?
If you have your own router, you can just plug it in and set to VLAN 911. No need for the Yayzi modem to have a modem mode really
my router doesnt do vlan, which is why I need it as a modem only - I have a xiaomi router, but its causing issues with Philips hue being on a different subnet etc
Which router is it as there are a few Xiaomi ones that support vlan I think
Ax6000
I didn’t know they even made routers, I thought they only did phones and 4G dongles…. More recently EVs
I don’t think you can do VLAN tagging (Ax6000) on the WAN tbh, unless you flashed the router with something like OpenWRT. Or you can purchase a very cheap managed switch then VLAN tag a port you will plug the ONT into then untag 911 on the side you want to plug your Router into.
Or there may be a way to do it using the Yayzi router, you can try this guide here How can I set up my TP-Link modem router as a pure modem?
