just wanting to know if I already had a direct set up before new portal came if it will still be up and running?
As the my Yayzi portal says there isn’t one set up and also says i have no Active services, how long does it take to update on it?
Rest assured if you had a Direct Debit before hand it will be setup on the new system ![]()
