I need to move my ONT about 1.5 mtrs and need an extension cable for the fibre input.
Can anyone recommend anything off Amazon that would do the job please?
Thanks in advance.
A quick edit: would this work?
Thanks in advance.
Looks ok OS2 single mode fibre.
This article shows a slightly different way of doing it but its still using OS2 fibre (as there is Multimode fibre -short distances )
Ih by the way thats 1 Metre and you want to move it 1.5 metres means it will be short
This is what I used to move ONT (35m).
Works perfectly. neat and tidy.
They also do the cable
Thanks for that, just measured again and I think I’ll just about get away with the 1mtr extension so I’ve ordered that.
