Okay so upon installing my Yayzi router my ONTbox ethernet light flashes and does not stay solid green is this normal?
I have 3 solid and 1 data light that flashes
Yes that is what i have on mine just wasn’t sure
yes is normal its the same for me.
Yeah, this is showing a data connection between your Router and the ONT. The flashing indicates traffic. Totally normal
It’s normal. It’s just showing you activity is taking place, the same as many other routers/NIC’s/ONT’s do, and the colour depends on the type of connection, eg green on my Nokia is gigabit, orange is 2.5Gb and I have yet to hook up a 10Gb port to it.
