Post Migration Speed
Hey all,
So we’re trying to figure out the issue with some of you having slower speeds. If you’re having issues please reply to this thread with the following:
Package:
Router Make & Model:
IP Range: (please leave the last 2/3 digits off, eg 123.456.789.XXX)
Speedtest (wired only, direct to the ONT if possible, please specify if you’ve done a direct to ONT or router) - Please use the speedtest.net desktop app.
Please post a screenshot of the speedtest as well, this will help us gather the information we need.
NOC
Package: 1200/1000 Gpon
Router Make & Model: Fortigate 60E 7.4.5
IP Range: 213.18.207.xxx
Speedtest This is through 10G switch infrastructure. Will try direct into ONT with another device if needed
2/1 GPON
UDM Pro Max
217.145.76.XXX
Speedtest Desktop App. 2.5GBe Wired connection.
Speedtest built into UniFi
Package: 2Gig Pro
Router Make & Model: Asus ZenWifi Pro ET12
IP Range: 213.18.200.x at the moment, will hopefully be 141.11.200.x when my static IP gets moved back
Speedtest:
Wired through router on 2.5Gbe ethernet:
Not in a position to do direct to ONT tests until after midnight, but I’m sure you’ve seen enough of my results on this already…!
Direct to ONT from Mac using a USB uGreen 2.5Gbe adapter
IP: 213.18.205
Unifi speed on 900 Plus package:
Speedtest fron a client PC: Speedtest by Ookla - The Global Broadband Speed Test
I would say that is within the margin of error - but it tends to hang around the high 900’s to low 1000’s
It appears as if mine has gone up though since this morning
Package: GPON 2000/1000
Router Make & Model: pfSense XG-1537
IP Range: 213.18.240.xxx
Speedtest Wired 2.5gb via router
Package: 2.5Gig Pro+
Router Make and Model: Tp-Link ER707-M2 v1.20
IP Range: 213.18.205.x
Speedtest: Direct to Router - wired 2.5Gb as per lowest speed confirmed in July. No Config changes my side since then
Woah, that is quite some reduction :hushed:
As requested:
Package: 1.2Gig Pro Broadband
Router: TP-Link EX820v (as supplied by Yayzi)
IP Range 213.18.x.y
Speedtest done by speedtest.net desktop app off a wired connection direct to ONT.
@Yayzi_Team
Hi team,
  • Package: 1.2 Gbps Pro
  • Router Make & Model: TP-Link BE550
  • IP Range: 213.18.206.XXX
  • Speedtest: My own TP-link router is connected to ONT. Several tests have been made on the laptop via Cat6A.
I checked with different servers as well.
Update: 20/12/2024: it keeps getting more and more unstable.
Router Make & Model: Unifi USG-MAX
IP Range: 217.145.76.xxx direct and 213.18.205.xxx via network kit
Speedtest Mixed
Direct to ONT
Normal networking
UCG-MAX → USW Pro MAX → PC
UCG-MAX → PC
UCG-MAX in build Speedtest
Still getting USA for Google etc.
Rik
@Yayzi_Team @mikekilley so I manage to sort this out and got my speed back to what they should be I when into the asus router settings did a speed test there and was getting over 2040mbps and 980mbps but Speedtest app showing 1500mbps and 980mbps which I was thinking is strange so I ordered a tp link router and did the same test get the same results
So what I did I roll back windows update did a speed test speed was improved by 100mb which let me believe something within windows blocking the speed I did a fresh windows install and run the Speedtest again and all speed showing correctly now I assume there is no fault with the asus router
Windows update causing issues? Unheard of!
Very strange but fresh install sorted it
That was exactly what I did, rolled back a windows update all returned to normal speeds.
@K3V1N very odd I when full fresh install sorted it
Have seen some bizarre networking stuff that only a fresh install of Windows can solve - almost like something gets corrupted but it’s not visible and everything looks correct but just refuses to work until a fresh install is performed.
I’m sadly going to say here that whilst this has been great for you @omar, I’m still convinced this is not the answer. I’m wondering if plugging in your Tp-Link router has somehow triggered something along the lines outside of your environment?
Also you said that the speed test on your Asus was showing over 2000Mbps - I just can’t get that at all.
And to add further to this, I’ve just booted up my mini PC with native 2.5Gbe ethernet running Ubuntu 24.x and this is what I’m getting:
So I’'m still getting reduced downloads. This proves (to me at least), that the issue isn’t within my local environment and isn’t related to Windows updates. My Asus router is running the same firmware version as it was pre-migration, and my Ubuntu mini PC was also getting full speeds previously.
And directly to the Yayzi speedtest server:
