Morning guys,
Not sure whats happened over night but the connection speed seems to have dropped massivly.
Morning guys,
What is running the test?
I test twice per hour and someone else tests once per hour, here are our results.
Mine:
Whilst he had a drop intermittently, it’s nowhere near the decline like yours.
Are you able to test using a WIRED device? rather than wireless?
(Second look, looks like speedtest.net app or alt) Which server are you using?
The way they are both limited to the same (100mbs) would possibly indicate to me this is possibly internal.
This is on my intel pc running homeassistant. The pc is plugged directly in to the router.
I test once her hour as I didn’t change the settings
You can ignore the erroneous result, as that is just the Speedtest server being bad, I need to force it to use a specific server going forward
That looks like your Ethernet adapter has set itself to Fast Ethernet, 100mbps. Possibly dodgy cable?
What is the link speed according to windows? That looks terrible
A reset of the yayzi router seems to have solved the issue.
