Supplier Switch Over Tips
Moving from Giganet to Yayzi tomorrow so only ONT swap required, currently use my own router UDM-Pro SE and all works fine
Any setting or changes I need to be aware of for Yayzi?
TIA.
All you need to do is set your wan to use the vLAN 911 then you should be off to the races :slight_smile:
Giganet also uses VLAN 911 you just need to change it from PPPOE to DHCPv4
Well hasn’t gone to plan today engineer turned up first thing did the ONT swap but had no service light all day, apparently CF engineer hasn’t closed his job so status is still showing committed. Been back and forth all day with yayzi support rebooting ONT.
But looks like no service till we start again to tomorrow.
Never needed VLAN 911 enabled on Giganet just PPOE
Cityfibre support client PPoE Connections with a VLAN ID 0 (default ) or 911.
Giganet transitioned from 911 to 0.
Giganet CityFibre connection installed prior to 1/11/22 VLAN ID: 911. All other services VLAN is untagged / not applicable.
At one point in time as quackers said above, Giganet stopped using VLAN and use PPoE. So he would’ve only needed to enable / use PPoE. Now he needs to switch to DHCP and VLAN 911 as McCZ said.
It’s all active now, was offline for 24 hours as I’m told the engineer didn’t close his job off so we had no service light on the ONT till this morning. Just need to wait for them to flick the XGS-PON Switch now so I can get the symetrical 2.3 speed. No timescale on that even though most of my area already has it
Clearly not :stuck_out_tongue:
I believe August is the month thrown around here a lot, maybe @Yayzi_Team could input here?
That was the rough date given by CityFibre but we’ve yet to get any further updates on this. We’ve chased them :blush:
If you think this is me being an arse, then I’m sorry for the poor life experiences you’ve had; that wasn’t my intention.
BTW, you don’t look a day over 40 :smiley:
Clearly you if you took the effort to reply.
God I love the elderly on the internet.
Maybe you two gentlemen can get a room and play nice on your own thread… :smiling_face_with_three_hearts:
