Upgrading my speed
I was under the impression that with the new account portal it would be easier and faster to upgrade…but there is no options to click upgrade…
To the best of my knowledge options to upgrade it and downgrade the connection will be opened up on the 16th of December, You should be able to do it from Monday
Ok thanks mate…will the option be integrated into the account portal then…
Yes, the option will be re-enabled in the portal
Sweet… thanks again mate
