I am getting one of these routers before cityfibre install my ONT. my question is does anyone have any info or used one of these routers with Yayzi or another cityfibre provider. Also when they come and lay last bit of fibre and install ONT box then is it just a case of my putting Ethernet cable from the ONT to one of them routers and away I go or is there more involved?
I haven’t used either of the routers you’ve mentioned, however I do use my own router. The process is quite straightforward, you just put the ethernet cable from the ONT into the wan port of the router. The only additional step you’ll need to take is to ensure that you put a VLAN tag on the wan port and set it to 911.
They should do - the key part is being able to set the VLAN tag, I was surprised I was able to do it on my router to be honest as it’s about 8 years old now
Don’t buy ASUS, they have a horrible history, especially when it comes to security and faking data for test certifications etc. - can anyone think of another OEM that had to agree to decades of external audits as part of a settlement? The Flint 2 is £110-145, 2.5GB WAN/LAN and runs OpenWRT (which ASUS WRT is forked from), TPLink do a number of different options and the supplied Yayzi router (EX820v) is surprisingly decent, especially for the £99 price.
Ok I may just use the Yayzi router then and maybe update at later time. What speeds can i achieve on the 2.5gbps wireless though if I’m using a wifi6E adapter on pc for instance?
