Hi Yayzi any ideas what going on tonight I rebooted but not helped much
Same here. Happens every night. Hoping it’s to do with the port speed that Yayzi are going to be upgrading as it’s pretty crap isn’t it? You should find it goes back to normal after a while.
Here’s mine:
Hi to be honest not noticed until now, I hope this is not a ongoing thing.
Anyone know why there is no WiFi on my account?
Definitely to do with the port, but the upgrade is in progress
Also, I’d ignore the portal. It’s crap, we’re bringing a whole new system online soon.
We’ll be sharing some screenshots of the new portal in the next few days for feedback.
Cheers for the honesty
How about beta testers?
Them speeds are mental 1700 download. What device & router is that on?
Just the supplied router
Oh okay I thought this was wireless speeds.
Yes it’s wireless speeds from the router using speed test on my phone
I’ve never had speeds of 1700 on my phone mind you it’s only a Samsung s22 ultra so a bit old
I’m getting speeds of under 95 mbps upload and downloads on a wired connection @Yayzi_Team please help.
Definatley something amiss @Yayzi_Team even slower than earlier
That’s even worse than USB2 speeds!
Did it resolve itself?
Not as of yet still slow obviously the @Yayzi_Team aren’t in work yet so won’t have had chance to look into it
Is wired test low as well?
That’s not bad for WiFi! I get 500/500 on my UniFi AC AP Pro, I need to upgrade it to 6E/7
Haven’t got anything to wire it to and the Xbox is never reliable speed test wise before yesterday it was 1.3-1.7 Gbps wireless
