VPN not working between 2 Yayzi sites
I have two Yayzi sites both with static IPs in the range 213.18.200.0/21 , connected together with IPSEK VPN running on pfsense routers. About 2 weeks ago this stopped working.
I believe that Yayzi routing is blocking access between the two sites. Traceroute fails between the two sites in both directions. However I can access other internet sites from both routers without problems.
The gateway for both routers is 213.18.200.1 set dynamically via DHCP.
Any ideas what to do?
I have two sites in this block as well and face the same issue. However, I am using a Wire guard VPN on Hosted on Unifi Firewalls.
[callumg] : so do you have Wireguard VPN working between the two sites? It looks as if I could get Wiregurad working on pfsense if necessary.
No Sorry,
I should’ve been clearer. I am facing the same issue. But i use a wire guard VPN Server
I contacted Yayzi to change the ip numbers so they are in different subnets, which they have done, and now the VPN is working.
Fantastic, I will see if i can get this done
