Website glitches
I noticed a few glitches on the website
  • link to X, bottom right of https://yayzi.co.uk/ is a bad ref to x.com . Should be x.com
  • Placing my postcode into the search bar doesn’t list all the addresses in my street (only 3, or 8). That’s probably down to cityfibre data? May not yet be up to date for openreach so a non-issue?
  • On the results page from a postcode search, the help and support link is dead and points to https://yayzi.co.uk/help-support
  • on that same page the forum link goes to a website error (https://hub.yayzi.co.uk/)
Hope that helps
That’s what happens with the X link
I think I mentioned the hub.yayzi.co.uk link months ago, but It must be at the very bottom of the list on their priorities
Ah, as long as it’s known. My bad I should have searched
New here - not yet a customer, but thought I’d do some give-back in at least pointing out some minor issues
They would certainly appreciate it, As do we On the community forum
Welcome to the community, by the way. I hope you are considering becoming a customer, They’re the best ISP I’ve been with
Good shout about the x username the correct one is https://x.com/yayzibroadband I think they’ve made a typo error in adding their account. I’m sure @Yayzi_Team will get that updated as soon as they can.
