Why do I never get Full speed
Hi Yayzi can you help to why I never get full speed, Just ran Speed test on two Wired Computers one is 1,364.0 Mbpss down with 13 ping and the other 1,227.3 down with 13 ping, done the usual restart etc,
Which speed test site did you use to check that, I find using the speedtest windows app gives the most accurate results, more so than even the speedtest website sometimes.
