I have just Yayzi broadband show up on my Telegram I just thought would double check was @Yayzi_Team before even messaging
When you say you had a request off them? What do you mean? Did they add you?
No it just shows up as they have joined Telegram. I have updated post to clarify
Have you still got the old number saved by any chance? I use telegram and haven’t had notification Yayzi have joined, and normally do with all contacts.
Whatsapp
Telegram
Just saved their old number and it shows in Telegram.
What contact number do you have? it goes based off that, I didn’t get a popup which I usually do when people in my contact join telegram
Yeah correct looks like there old number. I will delete it now.
Old number guys, would recommend to report and delete! ![]()
