Hi Everyone,
First time post. Apologies if this is in the wrong place.
TL;DR: what’s the best AX6000 mesh system that’s compatible with the TP Link Ex820V router supplied by Yayzi?
Long version:
I’m about to switch to Yayzi from Giganet as Yayzi offer 2gb broadband as opposed to the 1gb from Giganet.
I never used the supplied Eero router from Giganet as I have a tplink M4 (v2 - grrr) mesh setup. My home m4 unit is configured with the creds for the Giganet connection.
I’m excited about the EX820V router. The 2.5gb wired and WiFi 6E is of great value to me, but…
The EX820V supports easmesh and onemesh, not the deco standard. So I don’t think I can create a single mesh with the EX820V as the home unit.
This isn’t a super big deal as the M4s are limited to AX1200 anyway.
But I’m lost as to what extenders I can get for the EX. It seems TPlink don’t have any other AX6000 extenders. I can “live with” (first world problems) an AX5400 as I won’t notice the speed and important stuff will be wired in at 2.5gb.
It seems like the best one to get is the RE815XE:
But I’m not sure. I’ve seen that I can’t just take a second AX6000 router and put it as a repeater / extender (saw the forum post here and the OneMesh standard doesn’t like this)…
So is this the best option? Note I’m not able to use extenders over power lines, so this is ruled out I’m afraid!
Or - do I just keep the EV supplied router as an AP and create my own mesh (probably with better Deco units) that sits behind it.
Or - can I simply not use the supplied router and connect directly into the CityFibre connection with my own setup, like I’m currently doing for Giganet?
This last option seems a waste, as the router looks really good. But I do somewhat value the privacy of the system not being remote accessed / managed by my ISP.
HOPEFULLY this makes sense. Happy to clarify any questions. I would really appreciate advice from other users and or the team.
Alex
