IP assigned has a bad reputaiton 79.135.***.**
How about 79 addresses ?
@Yayzi_Team Just for my own sanity, you’ve mentioned here and in the pinned post that its the 74.x range that you’re moving, however I (and the others in this thread) am on the 79.x range - please tell me this what you mean and that’s its just a typo…?
Hopefully a typo and 79 was meant!
Because i started this thread can i have the best of the new IPs?
Like
149.148.147.146 for example :rofl:
Are we sure the 185.210 lot are OK then, even with the same bad rep scores?
It is known, and the move should get rid of that :grinning:
Those too :sweat_smile:
Yeah typo! Glad you’re all on the ball :rofl:
We have about 1000 customers on those addresses without any reported issues. So I’m fairly confident those are okay. We’ve been using the 185 addresses for several weeks now :slightly_smiling_face:
Migrated to new IP and disney and reddit are no longer blocked! Hurrah!
Same here. Reddit, Ticketmaster, Disney+ all fine.
Should all be back up now guys - anyone that isn’t and has done a reboot & a factory reset then me know :slight_smile:
Still issue with
Is it just me can others check if it works and post here ?
Can someone from yayzi just pop them an email and ask them to white list yayzi IP blocks ?
:+1:
We can do this for you! :slight_smile:
We use Brevo @work and I can log into our account fine. I haven’t tried sending anything via their SMTP though.
Are you connected via your works VPN or via yayzi directly ?
Not sure why these IPS are seen as proxy or VPN in the past but its freaking Brevo out. :upside_down_face:
Connected direct from home on the 185.210.x range.
Confirmed working and accessing apps such as ticketmaster on 185.210.171.xxx
Thanks for testing now fixed my side.
A bit of a late update here, now I’ve been moved to the 185 network I can confirm that all the little niggles that were left (specifically around banking apps) have been cured so thanks @Yayzi_Team you’ve had a manic couple of days, and I can see some people still have issues. From my side, coming from 30 years in IT, you certainly did your best in a tough situation, well done!
