Noticed speed has dropped to from 900 to 260 odd. around 13:00
Is something going on?Leicestershire area.
No speed issues here - Northamptonshire
My speeds also dropped to around 200Mb/s.
Same here in the Peterborough area.
Show off ![]()
1.2 Pro here on the 154.60 subnet
Guessing QoS isn’t currently on?
No QOS configured
NO QoS.
Was all working fine this morning.
CF issue or the migration?
This will likely be us doing work guys, normal speeds shall resume shortly ![]()
My trace shows 195.72.67.241 which with a little investigation would suggest perhaps I have not been migrated. Data gathered gives an appox location and I would say this is Telehouse West as I have been to that location in the past.
EDIT: Wow, dont I sound like a proper saddo - LOL
how long is “shortly” in yayzi terms? hours, days, weeks??
how low is too low?
Try a speedtest to a London location, like youfibre or something then post the results in here. Packet loss, high pings I’m 100% with you. However speeds as low as you’re experiencing is very unusual for Yayzi.
Is this on a wired connection or over Wi-Fi? If it’s on Wi-Fi can you run a wired connection test direct to the router? If it’s just as bad then I would do all the usual stuff, unplug router and ONT for a few mins, reset router to default and try again. If that doesn’t fix it email Yayzi support.
