@Yayzi_Team could you look into this please as currently only getting 600mbps over WiFi wired is the same when before it was over 1gb also I still haven’t been swapped to a UK IP
Taking a look ![]()
Huh… Since when was Yayzi, BT? no VPN running
Just checked on WhatsmyIP, it’s not changed, how weird
To edit this, I am thick - i have my iPhone plugged in to my PC, which I don’t usually and it’s using the hotspot (but the speed from the LAN)
Any update ? Thanks @Yayzi_Team
We’re seeing a 936 down and 941 up to your router, can you run some more speedtest for me and just post them here?
Can do any luck in swapping me to a different IP range ? Please 185 range would be great @Yayzi_Team
Rebooted phone and router and it seems to be sorted did change the channels for 2.4 and 5ghz and it seemed to sort it
I really must upgrade my wifi access points to at least 6E or 7 at some point, seeing that speed over wifi would be brill, even if there is no point to it
Thinking of these as they’ll be a direct replacement for the AC AP Pro’s
Access Point U7 Pro - Ubiquiti Store United Kingdom
Thinking of getting a 2.5g switch too
If your going to spend some cash go for the Access Point U7 Pro Max - Ubiquiti Store
2.5GB uplink will be helpful ![]()
Is the regular U7 not 2.5gb link? says it is on the page I linked
The only thing the promax has is 2 extra streams and that dedicated RF radio, which I don’t think is worth the extra, considering I need a 2.5gbe poe switch too
Main thing you paying extra for as you say 8 vs 6 stream on the Pro max. Both have 2.5Gbps ports.
The other main difference is MIMO on 5Ghz U7Pro is 2x2 4.3 Gbps (BW240) vs U7ProMax 4x4 8.6 Gbps (BW240)
Plus the pro max has fancy “dedicated spectral scanning engine for interference-free WiFi in demanding, large-scale environments”
For home use the 7Pro should be more than adequate.
I have one U6Pro - Works fine, all devices are 1x1 (Wifi4) 2x2(Wifi 6)
I would save the money on the Pro max and add funds for a 2.5GB POE switch.
I think only my phone is wifi 6 capable (iPhone 15 Pro Max) all my other stuff is too old ![]()
Point taken, I am running off 2 AC AP Pro’s (wifi 5) at the moment and I seem to be fine, 1 in the master bed room and one in the loft above the living room (could celling mount it, but honestly, it’s performing fine in the loft, if a little bit hampered in performance)
Hi any update on getting moved up ranges as still showing as the us
I can vouch for WiFi 7 speeds, it’s honestly beautiful.
I can vouch for this. The Pro Max is pointless over the pro, it’s simply made for more clients, that’s it. The Pro is exactly what i run and it’s amazing.
Probably best going here: IP Geolocation Issues (Please Read) - #60 by T9537
