Internet connection Gone again?
Yep rebooted and I now get “Your ISP’s DHCP does not function correctly”
@Yayzi_Team i was connected but no internet. Now reboot and it says dhcp does not work on isp
Still down here. I’ve rebooted my router. It’s not getting an I
Edit: Back up now. And also says Yayi as my ISP, which is new :ok_hand:t2:
Anyone still offline, just bear with us a few mins.
Your few minutes has gone onto more than 30 min now.
Back now
After second reboot still had isp dhcp not functioning message , then a minute later it sprung to life
Came online and went again. I was recieving NACKs back from the DHCP when my router sent the accept message.
Reboot sorted it
Shall i reboot or not?
Next time dont do this at 6-7pm because majority would be awake compared to 4am as suggested by you above
@rangara the traffic says otherwise, between midnight and 4am is a bigger peak than now. but yes, please reboot
Still nothing here. FY2. Been over 2 days now.
Think we’re still being worked on :slightly_frowning_face:
Worked after reboot
Is there a particular URL that the majority of the traffic goes to at that time? :grin:
I couldn’t possible say… :eyes:
Why are we still being worked on? Why is our issue different than the others?
Because there were a small number of failed migrations which means we’ve put you back on the old network to ensure you get internet still - This means a little bit of extra work. Just make sure router is set to Dynamic IP and VLAN 911.
It is
Yep, all set here too. I do keep getting an IP in the 154 range and intermittent access.
I don’t get any IP at all.
