IP Geolocation Issues (Please Read)
Sky is just not worth the money full stop, imo
Sky’s maybe if you watch a lot of TV
It could be that they check other sources like Ip2location. Since that has now updated it could be done tomoz. They update daily
Channel 4 app still not working for me.
All down to how quickly the supplier (Geoguard) updates and when the Website (C4) site updates thier own DBs.
It does but you can’t cast off the website to a tv.
You can if use iPhone to firestick or tv as I do it all the time
Most newer TV’s you can directly connect your Laptop / PC to the TV. I don’t know your TV model but if you google the model you can see if it supports it and if your PC / laptop does too then just connect to the laptop as a second screen and do it that way.
There’s no cast option on the Channel 4 website that I can find.
My TV is pretty old and while I have it networked I can’t find a way to send anything to it.
Android phone casting to Chromecast plugged in to the TV.
Win+K only works if the receiving screen supports it, which my TV doesn’t.
+1, Channel 4 app on TV geoblocked, 149.18.87.x range.
https://ifconfig.co has it as AS64286 (LOGICWEB), which is clearly wrong.
And here’s another one:
https://utility-switch.co.uk/utility-warehouse/
:frowning:
FYI this site is wrong. It says it uses MaxMind but they was one of the first to update. GeoIP databases demo | MaxMind
@Yayzi_Team
I contacted someone over at IPBase for you and got them to fix it today for you :slight_smile:
You might need to contact them if the ASN is wrong.
Can anyone confirm if doing this has fixed any issues for you guys?
Was it before IPBase updated. They did fixed the DB just after 4 I think
Have I fixed it! :joy:
No way it was just that shitty IPBase
Well done!
Awesome, what about the utility warehouse thing?
It’s a Wordpress site so idk if it’s local cache daily
Thanks :slight_smile:
@Lung @icarus @tomf @nexusmaniac (Sorry if i missed you)
Please could you try any sites you had a Geo block on again. As this issue might be resolved for everyone now :slight_smile:
The amount of times I have emailed ipbase and they send that email and nothing happens is unbelievable! -_-
Fair play and thank you!!! :heart:
